help post acid etch
arrowspark
Clarksburg MD
Hi I just finished acid etching but noticed that whenever the garage floor bwgins to dry there is white caking on it. I tried power washing it off 3 times now and it keeps coming back once the floor dries. Ayone know what it is. Is it normal or a symptom of something I didnt.do right during etching. How can I get rid of it? Will it effect the epoxy coatings?
Shea
California
That white powdery residue is calcium carbonate which is from the result of etching. It will occur when you don't flush and rinse your slab well enough. Usually though a power washer will remove it.
Try wetting down the concrete and scrub it with a salt remover/cleaner. Then use the power washer to rinse it. If that doesn't work, then re-introducing a mild acid solution to your floor again will emulsify the residue. Neutralize it, flush the floor with lots of water, then use your power washer on it.
