Help pricing a floor jack
nick__m
What would be a good price for this floor jack? Any idea how big it is or what brand it is? I don't have any info about it.
jdsac
Looks like it's at an auction. Usually auctions only combine items on a pallet if
they don't work or have low value. Try it to see if it works. The rust indicates
it may have been left outside- another possibility of it being a non worker.
CNGsaves
KS and OK
Hard to tell from the limited pics . . . . but I'd go $50 for the pallet if the tow straps were in the same deal . . . 2 for the money!!
Hiball
Missery
Its a Import, ONLY Judging by the Size of the Pallet compared to the Width of the Jack, Im leaning towards a 10 ton. That Design has been around awhile and sells anywhere from $800 to $1500 depending on what Color/badging you want Sunex/Otc/etc... If you cant Inspect it prior to purchasing.. I wouldnt give more than $150, I Used to buy alot of Government Auction Jacks and that stuff is Generally Abused and sits in a Yard somewhere for Years prior to getting auctioned off.
I guess it also depends on whether you buying it for Personal use knowing that it probably needs some Work or buying it to Resell.
BTW.. If its Only a 5 ton.. Versus the 10 ton.. Cut that $150 in Half.
fatfillup
Finksburg, Md
Well stated Hiball and thanks for the info.
Modified, you are absolutely correct on the plates, just a little low on what they will bring. I wholesaled a pair for $150 to a guy in the business of selling aligners.
