Help Re: 110 /220 volt motor wiring
Bones7
attached to the bldg
I have a stand up Husky compressor which is wired for 110 volts, the motor states 110 / 220 as per picture. Can I change the wiring to 220 and how would I do that :)
RPH
Michigan Thumb
It appears the white wire from the low voltage supply moves to tap 2. The brown wire isn’t connected but the have an isolated tap (6) to mount it to. Incoming lines attach to 1 and 4.
pattenp
Virginia - USA
Actually the motor data shows 120V/240V, so if you have only 110V/220V it won't work.
Sorry. Sitting in the house because of social distancing is bringing out the worst in me.
Edit: Oh shoot... alfred beat me to the punch.
Bones7
Thanks a ton! it works just fine, first nice day I will have the sand blaster out and blast my frame. As far as the 220 vs 240 thing goes, I'm located in Canada so it maybe 240 I don't know.
Thanks again for the info and all the replies.
:pimpflash
