Hey folks, gotta problem here.
Have a 60,000BTU Reddy Heater here thats not working. It had this problem last winter and I didnt fool with it. Needing it this winter.
I have attached a video to what it does. I poured out the old kerosene and put in some fresh stuff I just went and got. Changed the fuel filter as well after dumping it all. It still does it.
Basically what it's doing is kicking on for a few seconds and makes a "humming" sound then kicks off. a local repair shop is willing to fix it but I have to pay 30 dollars regardless if they fix it or not....kinda garbage.
so what could be wrong here? If you listen to the video, make sure you turn it up, my phone didnt record the sound too loudly. Thanks!
It is a good Idea to buy a low pressure gauge and attach it permanently to the port on the left in the back. a 0-15 psi is fine. It is a great tool, even if the device is working, so you can monitor the health of the filters, etc.. EVERYTHING on this device relies on the pressure hovering around 3 psi. (Pressures vary dependent on model, you can google that.) If you can not keep a consistent pressure, the unit will not work correctly PERIOD.
If it flutters fast, you probably need a rotor re-build kit. If you can't build pressure, there is something loose, or worn (like the cork gasket.) Check all connections. If you have the correct pressure, you get a good spray, and the HSI (Hot surface ignitor) glows, you may need a new photo eye. If you don't get a glow, get a new HSI.
