Help removing wire From Conduit
BillK
Beautiful Southern Maryland
AP514;8473828 The 4 other wires go from C/B in Garage to a lite Switch in the House for Lites on the outside corners of Garage((Flood 3-way Switch)) [/QUOTE said:
Just curious . . . . I did not think that was allowed by code ?
A switch loop for a 3-way light circuit breakered in the garage and switched in the house is permissible.
Since the source is the garage panel, there isnt 2 feeds to the garage.
A
AP514
Pearland, Tx
I knew my Electric guy did a good job....Too bad he did not put in 2 extra 3/4 drops ...But then again I never thought to ask.
Also just to be Clear the "Fiber Cable CAN NOT run thru my C/B PANEL in Garage".
Even if it just passes thru .....
Muzzy
Northeast PA
I ran the Fiber Cable thru Panel any way.....
Why would you post that after being told multiple times it was wrong?
Not sure that makes you a badass.
It was mentioned the shielded cable was for the garage door opener? Can you test voltage on it, specifically if it is AC or DC. If it was AC it wouldn't bother me too much being in the same pipe from an interference standpoint. The insulation on it probably wants to be the same voltage rating as the other conductors in the pipe though. Where is the shield landed?
