Help! Secondary pump isn't kicking on!
Flexia
Akron/Canton Ohio
Here are some specs. I have a navien ch210 combi boiler. I am trying to use the remote that comes with it as a thermostat. But it isn't triggering my taco relay so the secondary pump never kicks on. The boiler does fire up and circulate just fine and I do have the dipswitch for the external thermostat off
I have the T T from the boiler hooked up to the taco sr501 switching relay at the 6 n/o and at 5. Is this not correct?
F
Flexia
Akron/Canton Ohio
All I see there is "N", CN18, Yel/Wht feeding (1) pump directly. No relay...
Tommy
There is a relay its just sealed on the board. Here is the ladder. I was thinking about making a relay to hook the the pump wire to trigger the taco relay
Rookie2
Western Pa.
I would call the tech line !
All I see that it could possibly be is (outputs) T/CN26 or R/CN25 or that S block .
If you wired the taco sr501 correctly then by jumping R & W the circulator should run.
truckman5000
look at the sr501 wire diagram, you need to put a hot? jumper to the #5? terminal. As i dont have one infront of me, but the pump contacts dont get line voltage, without the jumper. Its a 24v/120v contact, bringing 120 to it would power the pump
F
Flexia
Akron/Canton Ohio
That's not the problem. I can bridge the R&W on the taco to start the pump. The problem is the boiler isn't telling the taco really when to turn on
F
Flexia
Akron/Canton Ohio
When I got home today I put my multimeter on the cn26/ external power. It does throw 120v out when the primary pump in the navien in on. I'll prob make a relay that will flip from that 120 and then it will bridge the R&W when flipped.
brewchief
How is the remote going to work as a thermostat? I thought you could only use it to adjust the boiler temp? Does it have any type of room temp sensor in it?
I would use a normal thermostat to control the taco relay and the aux contacts in the relay to turn the boiler on and off.
F
Flexia
Akron/Canton Ohio
Yes the navien remote can act like a thermostat. Has temp sensor and is programmable too
LS6 Tommy
Northern NJ
That's what I was thinking, too.
I got so wrapped up in trying to find a relay on the diagram I forgot to post that.
Tommy
F
Flexia
Akron/Canton Ohio
Just to update you guys. I used the external power term on the navien to flip a small 120v relay that then will bridge the TT on the taco relay.
It works for me but is an extra step. You could get a bigger 120v relay that will get triggered from the boiler to power the pump. But I already had the taco contoler
