Flux_capacitor_121
- Joined
- Dec 7, 2021
- Messages
- 10
I just picked these 3/4 full tanks off Facebook pretty cheap along with a Harris torch/regulator set.
I’m trying to determine the max draw I can put on the acetylene tank. It’s about 24 1/4” tall and 7 1/2” diameter. From the Internet dumpster diving I’ve done, it appears it’s a “WQ” tank with either a 60 or 75 cu ft capacity? I don’t want to grossly exceed the 1/7 (1/10 now) rule.
I’m not trying to run a rosebud or anything, just a 10cfh 6290-0 cutting tip. The torch came with a 6290 1AC 2-piece tip that Harris lists as pulling 18-36cfh. That seems a little much for this tank.
The oxy tank I’m pretty sure is an 80cu ft. It’s 36 1/2” tall (to the top of the valve knob) and 7” in diameter.
My main use for this will be automotive heating and cutting. Any help appreciated.
Thanks,
Joel
Thanks,
Joel
