nandomart
Im looking at purchasing a compressor with a 7.5hp 3 phase motor. I dont have three phase at my place, so Instead of buying a single phase motor Im considering a VFD. I found one with the specs below and Im hoping you guys can help decipher if this will work for my application..
Voltage (AC)
460 V
Phase
Three
Input Frequency
50/60 Hz
HP
15
kW
11
Amps
23
Efficiency1
97.4
Watt Loss2
342
Height
11.5 in
Width
4.92 in
Depth
9.49 in
NEMA 1 Kit
NEMA1LP4
Unit Size
M4
Weight
13.20 lbs
Factory Installed Keypad
Keypad
Enclosure Type
IP20/Open
Revision
1st Revision
Notes
Brake Chopper is included with 2HP drives
1 At rated load conditions
2 At rated load conditions
Environmental Conditions
Enclosure
IP20 (NEMA 1 with optional NEMA 1 kit)
Installation Location
Do not install in locations where product could be exposed to dust, corrosive gas, inflammable gas, oil mist, vapor, water drops or direct sunlight. There must be no salt in the atmosphere. Condensation must not be caused by sudden changes in temperature. For use at altitudes of 3280 ft. (1000M) or less without derating.
Ambient Temperature
-10 to +50 ºC
Ambient Humidity
5 to 95 % RH (non-condensing)
Vibration
1.0 g
Storage Temperature
-25 to 65 ºC
Standards
Approvals
CE, UL, cUL, and C-Tick
Suitable for use on a circuit capable of delivering not more than 100,000 rms symmetrical amperes for 230 V and 460 V.
WEEE and RoHS Compliant
Input Power Supply
Rated Input AC Voltage
200-240 Vac, 1-phase, 50-60 Hz, ± 10 % V
200-240 Vac, 3-phase, 50-60 Hz, ± 10 % V
380-480 Vac, 3-phase, 50-60 Hz, ± 10 % V
Max. Voltage Imbalance
3 % of rated supply voltage
True Power Factor
> 0.4 nominal at rated load
Displacement Power Factor
> 0.98
Switching on Input Power Supply
Maximum twice/minute
Environment According to EN60664-1
Overvoltage category III/pollution degree 2
Output
Rated Output Voltage
0-100 % of supply voltage
Output Frequency
0-200 Hz (Adv. Vector Control Plus Mode)
0-400 Hz (Volts/Hertz Mode)
Switching on Output
Unlimited
Accel/Decel Times
0.05 to 3600 s
Overload Current Rating
150 % of drive rated current for 1 minute
Control
Control Method
Sinusoidal PWM Control (V/Hz with torque vector control)
Switching Frequency Select
2 kHz
4 kHz
8 kHz
12 kHz
16 kHz
Operation Method
Keypad operation: Hand, Off, Auto
Digital Input: Programmable for Start/Stop, Forward/Reverse, Jog
Timer operation: Stop after predetermined time frame
Link operation: RS-485 Modbus RTU
Frequency Reference Setting
Up or Down buttons on keypad or external reference
Analog Input
Built in Potentiometer
0-10 Vdc analog input
4-20 ma analog input
Preset Speeds
8 presets via digital inputs
Link Operation
Drive RS-485 or Modbus RTU
Second Reference Setting
Switch from speed reference 1 to reference 2 via digital input
Trim Reference Setting
Available for speed reference offset via potentiometer, voltage input, or current input
Acceleration/Deceleration Time
0.05-3600 seconds (two acceleration and deceleration rates are selectable via digital inputs.
Acceleration and deceleration patterns can be selected from linear or S-curve
DC Injection Braking
Starting frequency: 0.0 to 400 Hz
Braking time: 0.0 to 60.0 seconds
Braking level: 0-150 % of rated current
Frequency Limit
0 to 400 Hz
Jump Frequency Control
2 jump (or skip) frequencies via parameter set to avoid mechanical vibration
Jogging Operation
Operation via On key or digital input (Fwd or Rev)
Auto-Restart After Power Failure
Restarts the drive without stopping after instantaneous power failure
Slip Compensation
Maintains motor at constant speed with load fluctuations
Energy Savings
Controls output voltage to minimize motor loss during constant speed operation
Start Mode Function
This functionality smoothly catches a spinning motor
Logic Controller (LC)
Logic Controller Events
Over 23 types of Programmable Events
Comparators
Array of 4 Comparators
Timers
Array of 3 Timers, adjustable from 0.0 to 3600 sec
Logic Rules
Array of 4 Boolean Logic Rules
Logic Controller States
Array of 20 Logic Controller Action States
Process Controller (PI)
Process CL Feedback Select
Analog input 1
Analog input 2
Local bus reference
No function
Pulse input
Process PI Control
Inverse
Normal
Process PI Anti Windup
Disabled
Enabled
Process PI Start Speed
0.0 to 200 Hz
Process PI Proportional Gain
0.00 to 10.00
Process PI Integral Gain
0.10 to 9999 s
Process PI Feed Forward Factor
0 to 400 %
On Reference Bandwidth
0 to 200 %
Indication
LEDs
Green - drive is on
Red - indicates an alarm
Yellow - indicates a warning
Voltage (AC)
460 V
Phase
Three
Input Frequency
50/60 Hz
HP
15
kW
11
Amps
23
Efficiency1
97.4
Watt Loss2
342
Height
11.5 in
Width
4.92 in
Depth
9.49 in
NEMA 1 Kit
NEMA1LP4
Unit Size
M4
Weight
13.20 lbs
Keypad
Enclosure Type
IP20/Open
Revision
1st Revision
Notes
Enclosure
Ambient Temperature
-10 to +50 ºC
Ambient Humidity
Vibration
1.0 g
Storage Temperature
-25 to 65 ºC
Standards
Approvals
Input Power Supply
True Power Factor
> 0.98
Output
Output Frequency
Switching on Output
Unlimited
Accel/Decel Times
0.05 to 3600 s
Control
Control Method
2 kHz
4 kHz
8 kHz
12 kHz
16 kHz
Operation Method
Analog Input
Preset Speeds
Link Operation
Frequency Limit
0 to 400 Hz
Jogging Operation
Slip Compensation
Energy Savings
Start Mode Function
Comparators
Timers
Logic Rules
Analog input 1
Analog input 2
Local bus reference
No function
Pulse input
Process PI Control
Inverse
Normal
Disabled
Enabled
0.0 to 200 Hz
0.00 to 10.00
0.10 to 9999 s
0 to 400 %
0 to 200 %
Indication
LEDs
Green - drive is on
