Help: Spiralux rivet tool
Bessy
Ontario, Canada
While attempting to (unsuccessfully) rivet some webbing to a tool belt (to attach a tape loop to my tool pouch) I got the tail end of a rivet stuck in my Spiralux rivet gun (English made). Took it apart, and a small piece of steel measuring 19.55mm long, 4.2mm wide and 2.55 mm thick came from inside the barrel I believe.
Anyone have a diagram or can give me an idea of where this piece goes and how to get it back in place?
Thanks
Sent from my Pixel using Tapatalk
Bessy
Ontario, Canada
Thanks, I will look at that this evening. It seems odd that they would use a piece of flat key stock rather than a round pin in that position.
dutchgray
Dorset. England.
It looks like it was punched out of a sheet, probably the cheapest way to make it, I would expect the side of the arm to be dimpled into the spring to retain on something made today, saving a part.
