Help Supporting Overhead Shelf
Mike65
Horse Pasture, Va.
In our last house we only had a 1 car garage & no basement & I needed a place to keep parts from my Mustang, so I built a overhead storage shelf over the garage door tracks. I cut small holes in the sheetrock ceiling & used 2x2's bolted to the shelf & run through the holes in the ceiling & bolted them to the ceiling joists. Worked great.
C
Colin Len
Long Beach CA
Well, shelves are up! But only supported temporarily with a piece of 2x connected to the beam above. I just ordered most of the remaining parts I'll need to put together the vertical all-thread supports and will hopefully get that knocked out this upcoming weekend. Yes, they're quite overbuilt. But I wanted piece of mind in case I ever put anything heavy up there, I live in earthquake country, and I wanted to ensure the plywood top & bottom pieces had plenty of joists to attach to so that they didn't sag at all.
Only sticking point left is that the garage door track mounts are just about where the rod hangers need to go. Still need to figure out if I'm going to move the track mounts or if there will be enough room for the rod hangers without interference.
lowbucktruck
Foothills, Northern California
Lots of good advice here. However, the construction of your shop matters when it comes to load - bearing. Hard to provide sound advice if we don't know enough about your build and what is a load-bearing beam in your ceiling. So take it with a grain of salt.
The chain or all-thread suspended shelves is a great idea, if you have something solid enough to anchor the top end onto.
In my old garage, I used a combination of all-thread rod, chain and Unistruct to make my suspended from ceiling shelves (and hog panel for the wire shelf "planks". But first I went into my attic space above the garage and basically reinforced my anchor points on the rafters (basically I made mini-trusses). I also used steel strap to provide better reinforcement for those anchor points, distributing the load across ceiling rafters rather than just one rafter.
C
Colin Len
Long Beach CA
Almost done!
19/32" Plywood tops went on first and then I tackled installation of the all thread hangers. Trickiest part was getting the Simpson rod hangers installed vertically. They aren't all perfect but close enough. Last step over the weekend was to install 1/4" plywood on the underside. Next weekend I'll wrap the edge with some 4.5" trim to finish it off and then they'll both get painted the same color as the walls/ceiling.
