Help to identify a tool set
martin_nj
Hi, guys. I found this set on an estate auction, it's marked "The Borg-Borman corp. waco tx" I could not find any info online about this company, it has different sizes "cylinders" that I assume slide inside a tube? some kind of cutter? and an electric motor, with a bunch of accessories in the original metal box. the is a paper that Says " This Threading unit has been inspected through all phases of its operation" but it does not look like a traditional threated machine?
Any information you can provide me would be greatly appreciated.
Thank you.
notlob
norcal
Looks like it says No. 01 on the motor and on the toolbox. Maybe there was never a No. 02? What else is written on the top of the toolbox?
Can I try?
SE PA
Could you provide a measurement of the outer diameter of the cylinders? For example, what is the outer diameter of the cylinder marked "4"?
martin_nj
Sure here are some picture with dimensions, also I think in the top of the box says "nippler threader" but its blurry.
