Mr. Roboto
Hi All, I have a Husky 60 gallon air compressor, model C602H
This is the compressor: https://www.homedepot.com/p/Husky-60-Gal-Stationary-Electric-Air-Compressor-C602H/205389936
2 days ago, I aired it up and noticed the motor was slow to start. It sounded like the pump was laboring to run too once it was going, as if there was some extra resistance. It aired up and cycled off, but did seem like it took longer than usual. Last night I went out to use it again. Tried to air it up from 80psi tank pressure, and it really struggled to start. It turned over a bit and got slower and eventually was barely spinning so I stopped it.
I let all the air out of the tank and started it with the hose disconnected so it wouldn't build pressure. It was very slow to start and didn't sound great. The oil is right where it should be, and I can hear the unloader letting off pressure when I turn the switch off.
I suspect I need to take the belt off and see if there is excessive resistance in the pump if I turn it by hand, although I'm not totally sure what a good one should feel like. Also, can I run the electric motor without a load on it to make sure it's spinning up OK? I suspect it is. Could it be the starting capacitor, or not, since it does start turning, albeit slowly?
The compressor is bolted to the floor and surrounded by cabinets so It's not the easiest thing to get to, so just looking for some advice ahead of time on what I can check when I find the time to get in there and start diagnosis. I don't have much experience troubleshooting a compressor.
Pic I had of the corner where the compressor lives, for what it's worth..... Thank you very much for any help. This is about the worst time for this compressor to die on me, as I'm in the middle of a few car projects. The compressor is just shy of 4 years old. I bought it brand new, and has only seen light home shop use.
