Help w/info about this hex tool
ihrescue
Olney, MD
Hi Folks:
I have had this for quite awhile and want to find out more about it and I would appreciate any comments.
The tool is steel, formed like an allen wrench and has a 3/8" hex like shape. There is one barely visible stamp that says Pat. Dec. 1918. Both ends of the tool look like they have a work purpose because they have the small spring backed ball that normally would hold something in place or together possibly with a sleeve or some other piece of a tool like a socket. The short "L" end has two formed ears about 1/2 inch from the end possibly as a stop.
Any ideas?
Thanks
Mike Love
a>
a>
a>
a>
a>
a>
Milton Shaw
Probably it's a handle for a set of sockets that would be able to be stored on the long part of the handle. The ears on the "L" shaped part of that would back this up they would keep the socket from sliding up the shank.
jakemac
New England
It's an ell-driver for a set of hex drive sockets. Kind of like a short breaker bar that doesn't swivel.
COL911
Virginia Beach VA
I have some extras, not in great shape, that you can have for the cost of postage. I'll dig them out and post pix tomorrow.
Here's what I've been able to piece together from bits I found.
R.F. Sedgley, Inc., Philadelphia, PA.
US Patent: 1,289,558 issued Dec. 31, 1918
See the full set in the schematic drawing HERE:
http://www.datamp.org/patents/displayPatent.php?id=28364
See also: http://alloy-artifacts.org/other-makers-p3.html#sedgley
Not Indestro - they get confused a lot - I see these sets on Ebay frequently.
They also get confused with New Britain / None Better. Also made by G.M Mfg. Co., Long Island City, NY and other makers.
Japan-made knock off similar to what your Sedgley set looked like:
http://www.ebay.com/itm/Vintage-Soc...315645?hash=item3adbc665bd:g:FGwAAOSwopRYldqB
very similar no-name US-made set:
http://www.ebay.com/itm/Vintage-1-2...763875?hash=item3f76203ce3:g:0FIAAOSw9GhYaEAJ
another similar no-name US-made set:
http://www.ebay.com/itm/VINTAGE-HEX...951414?hash=item1a25f4d2b6:g:JqgAAOSwA3dYfSSR
another similar no-name US-made set, but in 1/4" drive:
http://www.ebay.com/itm/Vintage-Mec...969321?hash=item1a252ebb69:g:q2UAAOSwM4xXb0cM
another similar version with a stepped socket:
http://www.ebay.com/itm/Vintage-All...028768?hash=item41aaf490a0:g:oGIAAOSwG-1WukEG
and the New Britain "None Better" / "Handle Lock" set I mentioned above that uses essentially exactly the same "ELL" handle, but incorporates a ratchet, drive adapter, and the handy-dandy tote tray:
http://www.ebay.com/itm/Vtg-Pat-Dec...557277?hash=item282d6924dd:g:U4MAAOSw44BYS4ke
I
ihrescue
Olney, MD
COL911 - I am interested in the bits you have. If you can let me know USPS Priority Postage and your pay pal email by personal message I will send you postage funds. By the way do you know who the manufacturer is? Thanks
I
ihrescue
Olney, MD
Hi SweetD - The day before I started the thread I began putting some Kroil on the detent balls. Some light taps with a small ball-pean hammer gives the feel that the detent balls give and spring back so I will keep working them.
Mike
I
ihrescue
Olney, MD
Four.cycle - thanks for the many notes and links and the time it took. My guess is that it is a Sedgely since it has the December 31, 1918. It looks like the design idea had some followers and thanks for clearing me up on the difference between the Hexall tool and others.
Mike
Bdgjr215
R.F. Sedgley also customized guns at their factory.There is a street named after him near
Where his factory was located in Philadelphia.
I
ihrescue
Olney, MD
Well if there's a street named after him he must have been a valued contributor to the community. I'll have to look into that. Thanks for that info Bdgjr215
COL911
Virginia Beach VA
Mike,
Here are the extra sockets I have. No marking, kinda rough, but it's a start. Look this pic over and confirm. I can do PayPal or if you prefer you can just send funds covering postage after you get them. I'll even be in Hagerstown/Frederick/Woodbridge area for work week after next if that's an option. Whatever is easier.....
COL911
Virginia Beach VA
Close up of the knurling pattern, identical on the ones I offered up and the ones I'm keeping
Yes. Just chase the patent number (or patent date or makers name) on Google and you'll find it.
Google search "patent by date" - click the link to the DATAMP site
enter patent number (or date) up at the top - hit "search"
pick through the list on the next page until you find a match. sometimes you'll have to check two or three different patents before you find a match - simple process of elimination.
easy peasy.
I
ihrescue
Olney, MD
Yes Four.cycle your process confirms it. Thanks for the comments as that helps me in finding some other unique soccer wrenches I have that I need to track down.
Mike Love
