Help w/special roller chain
toadjammer
WI
I am need of some special roller chain and the first obvious place, the local farm supply doesn't have any and Mcmaster doesn't have it best I can tell and Grainger wasn't easily navigable. The chain looks like a standard single row 60 series chain but the rollers are .331dia. instead of the ansi .469 dia. Any help would be greatly appreciated.
Thanks
Toad
Farmallgray
Spring Mills, Pa
Could it be metric? Check with a motorcycle shop. I know there are some standard/ metrics that are semi-interchangable.
Are you sure you don't have 60-H (heavy)?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Just a shot in the dark.......How are you measuring the roller diameters? If by dial calipers make sure they aren't .020 off (this is what they jump when a piece of dirt gets into the gear rack) That would make it a standard chain at .312. (.331-.020= .311) And if per chance that would be it, then it would be a standard roller chain with the ANSI No. 40.
Or check out the Diamond Non-Standard Series http://www.diamondchain.com/files/Non_standard.pdf The Diamond 867 shows a roller diameter of .335
JOHNMAN
Southwest Indiana
What is the pitch length of the chain? Measure center of pin to center of pin.
Typically, the size of the chain is stamped on a side link of the roller chain.
I have heard of over-sized rollers on roller chain, but not under-sized rollers.
Take a picture and post it.
