Help w TEREX TS26
Davecolston
I've an old TS26. Suddenly, it wil go up and come down by the using the Ground Control Box only. When I attempt the same from Aerial Control Box, it will go up for but not down. Any ideas would be appreciated.
Dave C
seber
Deep East Tx.
Yes. It is most likely just a broken connection inside the switch. If not, then a broken connection elsewhere, but I'd check the switch first. All you need is a continuity checker.
