Help! Walls made of OSB problems
niterider006
Hi all, First post but I've been lurking for quite some time. OK, so here's my story:
I'm in the process of finishing up the garage. I had to run to Home Depot to pick up a few more supplies while my cousins were busy cutting OSB to be hung on the walls. (Perhaps not the best but it was cheap) Well, it took me much longer than usual to get back but to my surprise, many of the OSB sheets were hung up. Great, right?
After looking over the OSB, I noticed that some of the seams were protruding out as much as a 1/4 inch. It turns out that that while they were hanging the sheets up, they did not pay attention to making sure the seams were on the stud. Thus, some of the OSB is bowed in due to no support on the seams. :eyecrazy:
Everything is nailed up really good with 3 inch roofing nails. I planned on caulking the seams with some paintable silicon but no amount of caulking will hide those uneven seams. What's my options here? I would hate to have to pry out every single sheet of OSB considering the nails are about 1/8 inch through the wood. Will something like mending brackets work? Eventually I;'m going to throw some mud, primer and paint and hopefully get it to look decent. Any help would be greatly appreciated!
ilovevocs
Toledo, Ohio
Your best bet IMHO would be to rip down the same OSB into 4" wide strips and install it at the seams with a brad nailer. Your going have a board and batten look but those seams need supported from the front or the back. The latter option seems to no longer be an option.
N
niterider006
*sigh* I really wanted to avoid doing that since it's going to be a royal %#$% pulling them off.
PugetDude
Superstition Mountains, AZ
...I had to run to Home Depot to pick up a few more supplies while my cousins were busy cutting OSB to be hung on the walls.... Well, it took me much longer than usual to get back but to my surprise, many of the OSB sheets were hung up. Great, right?
We definitely need a picture of those cousins....
N
niterider006
They have already left town and good thing too because I was pissed. Anyone have any experience mudding over mending brackets? I was wondering if I could use those to bring the seams flush. Maybe furring strips are in my future.
Ed Litsch
Riverside
While you had help, you should have had put up drywall. It looks a lot better than OSB and it's cheaper, too.
gjz30075
Roswell, Ga
How about just cutting up the middle of a stud with a circular saw to eliminate the overhanging part, on either side, to be able to nail in a sheet on studs? I think it'll be less work than tearing it all off.
BFBOB
If you can't hide it, make it into a design feature.
I think your best bet at this point is battens. Use lots of glue - Titebond II water resistant, or a non-hardening construction adhesive. OSB isn't that strong to begin with. Brads will be iffy. Drywall screws much stronger, will pull the panels into alignment and still pretty quick. Make the battens pretty wide - I'd say 3-4".
That's your easiest viable option. cutting the sheets at the studs would probably not be satisfactory. I doubt your cousins got those nails perfectly in line, and even if they did, but the time you saw so you miss the heads, there won't be enough stud left to nail into. You'll have to put in 2x2's on each stud to give something to nail the OSB to. Still, if you insist on a smooth surface, that's your only option. Mud over mending plates??? No way.
Good luck, and how about some pictures? When your anger has subsided enough you can hold a camera steady!
SteveCh
I'm sorry, but I have six adopted golden retrievers. They are no great shakes in the intelligence department. But they are smarter than a bucket of gravel, by far, unlike these guys.
Easiest thing to do, I'm afraid, is rip it out and do it over with new panels. In the long run.
Now that I think about it, no one is that stupid, so I think these guys must've done it on purpose for some reason.
Jack Olsen
Los Angeles
iBuckethed
North AL
1. Use a plug cutter (the one shown is just one example) to drill out/around the nail head.
2. Pull the OSB away from the studs and set aside.
3. Remove the the protruding nails.
3. Reposition OSB, nail.
I would rather patch a bunch of small holes than fill seams. Of course, your cousins may have nailed every three inches up an 8-foot wall. :dunno:
-iB
djjsr
In the cornfields
Roofing nails have big heads. You may be able to pull the panels loose without the nails damaging them. Give it a try on one and see what happens.
73super
Renton, WA
I like OSB on walls too.. hold up much better than drywall. How did the cousins not know to attach sheets to studs..? What DID they attach the sheets to?
Thruxton
Virginia
Could have been nails for the underlayment- small heads. I'm always the optimist...
N
niterider006
-iB
Now that looks like an interesting option, especially since the nails are pretty deep.
N
niterider006
They are attached to studs, just not laid correctly so that the seams are at the studs. Some of the boards were slightly warped which compounded the issue. Apparently, the studs were not exactly 16" apart. Well, that was their excuse anyways.
At this point, I might just say screw it and tape/mud the seams. It is a garage after all and not my dining room. But I'm afraid of it moving and cracking as it can get pretty hot and cold here.
N
niterider006
I like this idea, but too bad the wife doesn't. I'll try to get some pics up later.
N
niterider006
Tell me if you think this would work: Cut out a 5x5 inch square near the middle part of the seam, shove a small block of 2x4 in there in both the top and bottom of the hole and nail it to the sheathing, place the square back??? Sorry, just trying to think outside the box.
dirttracker18
Slate River, ON
:deadhorse
OSB in my working shop, drywall in my parking garage. JMO
MY opinion of your situation is that you work around it until you get some kind of **** *** artistic look.
or
You take it down and do it right.
Totally your choice but I couldn't live with it like that and I am sure it will cause some headaches down the road as the OSB shrinks and expands.
JakeKohl
Greenville, SC
Lots of nails for the blade to contend with....
What about leave it up and just put a second layer of OSB up that IS aligned correctly? Your wall gets a little thicker but you save the tear-out...and most of that you tear down won't be reusable anyway.
And, BTW, I would screw it to the studs so you can do stuff with it later if you need to.
buddyboy
leave the OSB up.
nail up some 1/4 osb over the top of what you have up there except this time put the seams on the studs.
heck, throw some P/L premium on it while your at it and you'll have a wall that will never come down.
N
niterider006
Interesting... have you used this technique before?
It's new to me but a buddy of mine tried it. It's mostly an oil based primer, mixed with a little bit of mudding. 2 coats and the OSB looked smooth. So I was thinking about doing the same. I haven't made up my mind on that yet though.
Twiggss
middle
3" nails to hold up OSB? you sure that is enough? I'd grab some railroad spikes next time.
Woody610nb
Concord, NC
If you take down every other sheet, you could place a stud behind the seam of the sheet that you left. Reapply the sheet you took down.
Vegaman_Dan
Pacific, WA
For the sheets that have hanging seams in the open, remove or pry the nails and sheet back on one side only far enough to slip in a splicing plate made of more OSB sheets, about 12" wide. You can screw through the face of the fixed sheet into this plate, then let the original sheet go back into place. A few more screws on either side of the seam and you'll be set.
Depending on how many sheets have these hanging seams, you could save yourself a lot of time over removing the whole mess.
kelzamos
Central Illinois
^I like easy and simple. This is the way I would go.
