Todd.Brock
Hey all, I need help doing the layout for a basement bathroom. I intend to have one recepticle by the sink, one can light over the shower, 2 wall sconces over the sink and one exhaust fan. The bathroom has 2 doors. I would like to use a 3 way set up so the lighting could be controlled at either door. The fan will be switched.. I would like to have the sconces and can switch separately, but I dont have the stud space for a three gang box. I will have to wire the sconces and can together on one switch. This will let me use a two gang(lighting and fan)
The panel is about 15 feet away. I only having two open breakers left. ( House is 2 years old, 200 amp service, Cutler Hammer CH series box and breakers)
First: Do I need 1 or 2 circuits? I have been told to use one 20a circuit wth a 20a GFI breaker so the whole bathroom is protected and others have told me to def. use two circuits. The biggest dilemma (other than a possible code issue) I see with this is if trips, you are in the dark and have to go into the storage closet to reset.
Second : If I use two, what should be on one vs. the other?
I bought a roll of 12ga. so whatever I do it will be in 12 ga. even if it only needs to be in 14. I havent opened anything yet so anything can be returned. I have a small roll of 12-3 for the 3 way setup.
Can some one please help me out with the best course of action. All work will be visible until the remainder of the basement is finished (possibly never) and may even sell before that happens. I would like to stay up to code and if an inspector ever looked at, it would be approved.
