Help wiring an ac motor
Jweebothee
Albuquerque, NM
Hello all, I'm needing help trying to wire an ac motor, it's a GE 1/3-19 hp IMG_2482.JPGIMG_2483.JPG
Never had to wire one before thanks for any replies
rkevins
Central Arkansas
does it have a wiring diagram on the motor if so can you post a picture of it?
what voltage do you want to use?
if there is no wiring diagram post a picture of the model number.
rkevins
Central Arkansas
neutral goes to #1 hot for high speed goes to #3 hot for low speed goes to #2 the without actually seeing the wire I would guess red and black should be hots and the white neutral
does the cord you show have a high/low switch on it? if so you will have to ohm it to see which wire is high and which one is low or wire it up and if it is wrong swap the 2 hots
