asterik216
So I got the motor with all the cords cut and everything basically disconnected. I have looked bunch online for the same model wiring diagrams. I have found some that only have 1 capacitor but none with 2. When looking for just general diagrams they always show the capacitors as having both leads connected separately but these are all connected together. I am pretty sure the blue is start the white is run and black is common as long as I did it correctly going from highest to lowest Ohm's. It originally came with a 6 pin rocker switch I believe but I only have a 6 pin 3 position switch that I also need to wire. I don't think that makes a difference as it is still 6 pins but im no expert. I did have it wired up as best I could from what I found online and it would just buzz when you flip the switch. I read that could be something to do with capacitors. Like maybe I didn't have them hooked up correctly.
Any help would be greatly appreciated.
