bestonearound
- Joined
- Mar 11, 2012
- Messages
- 10
Hey folks,
I got a Quincy air compressor for $500 bucks. It's a FF325 with a 325-18 compressor and a 5hp Baldor L1410T motor 240v single phase.
I do not know how to wire it back up, and I don't know how to properly replace the pressure switch? I'm assuming is the black box with three wires.
The faded reds go from the pressure switch? to the motor wiring and wire nuts. The green goes from the pressure switch to a ground just inside the motor's wiring box. I am thinking that the black wire and blue wire connected together to one of the faded reds that run to the pressure switch and the yellow wire and the (newer) red wire connected together with the other faded red running to the pressure switch. Is this correct? Thank you.
