Help with ceiling boxes for lights
adrenalinejeeper
Ventura County, CA
We used 4" square metal boxes for a 4x4 grid of lights, but since the ceiling had to be double 5/8" drywall we put 1-1/4" mud rings so it would sit flush with the face of the drywall. I ordered 16 Bees Lighting 2-lamp T8 fixtures, expecting to hang these directly to the drywall over the 2-gang opening, utilizing the knockout in the center of the fixture for the wires.
Unfortunately, the 2-lamp fixtures aren't wide enough to fully cover the opening in the drywall, leaving about 1/2" on either side open. I thought I could just add a flat 4" cover plate with a knockout in the middle, but the mud rings have 4 screw holes intended for a normal 2-gang wall plate. All the 2-gang blank metal wall plates I can find have too much depth to them to allow the fixture to sit flat against the ceiling.
Short of buying flat stocks of metal and setting up a jig to make my own cover plates, does anyone have any ideas?
Photo of the type of mud ring used:
A
adrenalinejeeper
Ventura County, CA
bamawildcat
Bert_
NW Iowa
The right thing to do would be to remove the boxes altogether and run the wires directly into the light.
The box behind the light needs to remain accessible once the light is up. A 1/2" knockout in the center doesn't cut it.
A
adrenalinejeeper
Ventura County, CA
That doesn't seem right... I can't have romex just penetrating the drywall straight into a fixture.
From my understanding, accessibility with hand tools is still considered accessible, unscrew the fixture from the ceiling, the cover from the box, and there it is.
Bert_
NW Iowa
If the light is attached to anything other than the box then the box needs to remain accessible.
Romex into the back of the light is the simplest way to do it. The box serves no purpose. The splice can be made in the light. The light IS a box.
sparky 1971
Central Iowa
Is there any slack above the box that can get pulled in? If so, my suggestion is mount the fixture so that it covers one side of the box, but leave the screw holes on the other side exposed. Pull the wires into the fixture, the fixture is now the junction box. Get a single gang nylon plate and cut it so that it covers the exposed side of the box and butts up to the side of the light.
yatg
Southern Oregon
If its a direct wire fixture, it should have a big knockout in the top to allow access into the box. Get a 2 gang blank wall plate and cut a hole in it to match the fixture knockout.
cybrdyke
USA
^^^ This.
Boxes in the ceiling are dumb, in my opinion.
Do you realize they need to be GFCI protected? How are you gonna do that?
CED
A
adrenalinejeeper
Ventura County, CA
Yes, we left enough slack to make the connections in the lights, not in the box. I like your idea, if I can’t figure out a way to have the lights directly lined up I’ll do that.
This is my first thought as well, I’m just hoping the blank wall plate doesn’t protrude enough to keep the light from sitting flush to the drywall.
^^^ This.
CED
I’m not sure how to penetrate drywall with romex in a fire ceiling other than through a box, this was what the inspector wanted and my electrician went along with. They’ll be GFCI protected at the panel. Every circuit will be combo arc fault and GFCI protected as required.
Toomanytools?
Washington
You can use fire block caulking (orange) to seal wire penetrations through sheetrock.
