C10Dan
Hi all,
I'm just about finished with my new pole barn workshop and still have to pour the floor. I have an opportunity to buy some reclaimed 2" or 4" thick XPS insulation at a very good price and would like some feedback. I'm leaning toward buying the 4" 40 psi rated XPS, but wanted to know if it's overkill and worth using. Or should I stick with 2" 25 psi rated. It appears now that some codes require the use of 3" in some areas, so is 4" going to be better? Or is there a point where too much doesn't buy you anything?
First of all some history. The building is located near Buffalo, NY. I'm planning for in-floor radiant heat. The building is 46'X48' with 14' high ceiling. The new building is actually an addition where the back of the building (46' width) is attached to a 40'X40' pole barn. The front has three 12'X12' insulated doors.
Walls are insulated with 4' wide R19 fiberglass with poly vapor barrier. The ceiling is blown in fiberglass R49. I ran 4" thick vertical foamular XPS between the post columns down 2' deep. I would have liked to go deeper, but it didn't work out that way. Hopefully 2' down will be deep enough. The vertical insulation is flush with the column posts. I'm planning to pour the concrete floor flush with the posts, and against the vertical insulation, so the edge of the slab is insulated.
I plan to use 10 mil Perminator under slab vapor barrior then my XPS insulation. So what do you feel about going with 4" XPS under the floor? The cost is about $675 more then the 2" XPS for 2,200 square feet. Is it worth the extra money? Thanks for your feedback.
Dan
Dan
