Colin Len
Might be a bit strange of a question but I need to tackle this project tomorrow after work so that my painter can finish my trim this weekend and was hoping to get some help on a technique or tool to use.
I recently had the roof replaced and some fascia boards added to some of my eaves. I had some issues with the guy who did the fascia and parted ways with him prior to him finishing up the last details to tie the original decorative trim on the gable ends into the new fascia. I now need some help figuring out how best to finish this myself.
It's a little hard to tell in this pic but you can see the the gable end trim just stops abruptly where it overlaps with the new 6" fascia board. I have some extra trim which was removed during the roof/fascia project that I can use to finish off these ends. What I'd like to do is to use a small piece of the spare trim to put a 90 degree "turn" on the trim so that it turns and terminates into the fascia.
In the picture shown this should be pretty easy, just cut a piece and nail it in place at 90 degrees to the end of the trim that's already there. Unfortunately in some other areas the original trim is damaged on the end so I'd like to cut the damaged area off to create a nice clean line I can join to the trim piece I'll be adding. But how can I cut this trim when it's installed on the house? It's covered by edge metal from the roof and I'm not sure if that is easily pulled away or if there is a special tool that would make this easier. Hopefully that makes sense, I had some trouble figuring out how best to explain what I'm trying to do.
Any help is greatly appreciated!
