NewShockerGuy
Saturday we got a TON of rain. More so that I can remember in a long time. This type of rain is rare. Raining hard in the morning and didn't really stop until the night. The back yard was filling up with water in places I never noticed before and especially around the shed.
I see a couple problems but not sure how to really fix it. My house is beside neighbors, but there is a hill on both sides of the house, so the run off goes into my yard.. nothing really I can do to change this. The two problems I think I can fix or mitigate. The neighbor on my left has drain type thing in the middle of his yard and then that ends up draining into my back yard. When there is a normal rain it's not bad, but Saturday it was clear how much water comes into the yard from that thing. See picture.
Next is all the water pooling around the shed. The ground IS lower there slightly. I have made a make shift drainage but it still is a problem. The water was so high it was to the bottom of the trim of the shed. It's never gotten that high before.
I wanted to somehow grade the back yard slightly. First is making sure that all that water on the left from my neighbor is not going through the yard. Do I put more soil on my side so that the water can't come through the fence? And if doing so would it then just move to another spot in the yard. IE: If I build up one side it would just travel until it reaches a lower point. How do I make it not go in the yard? Behind the yard in the common area is fine.
The shed is surrounded by river rock and actually has some pavers in the back. I was planning on removing ALL the rocks on the left side/back, and building up that area with soil and then toward the back near the fence but still in my yard, channel the water to go behind and out the shed. I would then redo that area slightly by putting down some sod and making the actual profile of the river rocks smaller on the left side of the shed.
I will note that when I pulled some of the larger river rock out from the side and back drainage was improved as you can see in the later pictures. French drains won't help here but there is no problem channeling all water to behind/common area. There is a picture of the dry pond that is completely filled in the back ground.
I've never done this. What type of dirt do I need? Top soil will get washed away, VA has clay like dirt, so when you dig there is dirt but there is clay.. Do I take the grass and cut underneath (like sod) put dirt down and then put the grass back over it? Or do I just but the dirt on top of the grass and pack it down, thus killing the grass? Is there a good time to do so? I do aeration/grass work late September/mid October so I don't mind messing the grass up but would prefer it to be messed up around that time frame...
I guess what I am asking is how do I do this properly. I do not have machines or tractors or anything of that nature. Just normal manual labor, wheelbarrow, shovels, rakes..etc. Typical home owner stuff.
Pictures show flow of water, then the last couple show when the rain slowed down and after I moved some pavers. Apologies for some blurry pictures. Trying to take them while holding an umbrella were hard and getting wet/windy.
Thanks,
-Nigel
Thanks,
-Nigel
