I'm going to be installing a Fan and lights in my garage and would like to run them from the ceiling outlet (for the door opener, thats not being used) I want to put in a 3 gang box with Fan control, then light switch, then outlet as there is currently only a single outlet in the garage. I think if I run 14-2 from the ceiling outlet to the Fan outlet, then 14-3 from fan to 3gang box, I can get everything working right. Does this sound like it will work to everyone else?
Ceiling outlet ..............Fan.................... Switches/outlet on wall
black...........to........black(bypass fan).............to fan switch (and pigtailed to others)
white...........to..............white.......................to white for outlet
##........................Red to black on fan............to switched out put
And a second line of 14/2 for the lighting off the light switch?
Maybe this helps... yellow = white line/nuetral
Any help?
Any help?
