nate379
My house is sealed well enough that there is a makeup air setup. I imagine this is kind of common on newer houses.
What that is is a 3" PVC pipe that runs through the top plate of an interior wall (in my hallway) and goes up over the insulation into the attic. At the bottom of the wall there is a vent.
I noticed when I had first bought the place if the dryer was running it would make a bit of neg pressure in the house (like a vacuum). Open a door and it would pop open, and it would be hard to close.
If the bath vents are on or the range vent it's even worse.
I put a woodstove in the house this fall and without a window being cracked open, it will pull smoke in the house. Now the stove has an outdoor air kit, but even still there is enough vacuum in the house it pulls through any little crack. It doesn't smoke out the house, but enough to smell it.
I talked to the builder and he wants to add another pipe, but doesn't know what size to go with.
Want to keep it as small as possible for less heat loss, but fix the problem. I suggested doing another 3" but putting a reducer to 2". If the 2" isn't big enough, just would need to pull reducer off and 3" the whole way.
#1 I was wondering is there any time of baffle/flap that would allow air to come in but not go out of that pipe?
#2 any ideas how I could figure CFM of devices and base that on pipe size?
1 window open about 1" is enough to make up what the pipe can't do. Window is 2ft wide.
Bath fans are around 100cfm, but I have no idea on the range hood or the dryer.
