Help with Hydro valve
electromech31
Well guys Im stuck on a hydraulic press and lift table.
My problem is my used Vickers valve. I got it at s very reasonable price for what it is. Its a alunimum body with input/output ports, with three valves bolted to it. I have not found number on the aluminum body. There are numbers on valves ,Vickers DG17V-3-2C-60, MODEL CODE 02-127343. yg
E
electromech31
What I am trying to do is power a two-way cylinder on the hydraulic press. And also power a one-way cylinder with gravity feed down on the hydraulic lift table. But the valves on there are two way valves. So if I can use these valves set up I have now that would give me one extra valve the play with later. Such as for a tube bender of some type maybe. But my hydraulic experience is very limited and I don't know how to get a two-way acting valve to work with a one-way cylinder please give advice. Thanks guys
E
electromech31
In the above photo shows you all the valves are configured. This project has been going on two years and unfortunately I have not gotten any farther with it in the last 2 months.
