warren57
Hi guys, have a unique project to start and could use everyone's advise.
I am getting ready to replace my kitchen cabinets, but the existing were built in place custom sizes from years ago. I upgraded with granite tops several years ago, but now it's time for new cabinets.
I am going to leave the granite in place and demo and add one new box at a time. The granite removal/reinstall would be nearly impossible and certainly cost prohibitive, as it is in various heights where the tops are on cabinets and changes to breakfast bar. They overlap one another and are stacked. So, although the easiest method to change cabinets would be demo everything and start over, I won't be doing that.
As each wall is a continuous single unit, the height is actually about 1/2" taller than a standard cabinet, so as I demo, I will be able to slide a new unit in with no problem. I figured I could leave the horizontal attachment on the walls that support the top, slide the new cabinet up to the existing wall strips and attach. I can add a temp support leg on the outer edge that overhangs to support the front until the new unit is in place.
So here's the real question. How to level the new unit under the existing top. Since it has about 3/8"-1/2" clearance, what options do you see?
Corner brackets with leveling legs to get it tight to the bottom of the granite?, or should I be keeping the bottom solid in the floor trying to shim to the top?
Let me know your ideas, I only want to do this once!!
Thanks
Thanks
