I was going to use 4x8 foam boards with a foil facing towards the garage floor, but I keep getting told it’s not to code..Buy on PC of 2" XPS, lay it across 3 rafters, and see if the sag bothers you. Seams taped, it would make a big difference. Honestly, just poly would make a difference, so I guess reflectix would too, but 2" of XPS a lot more. Don't use anything with a flame inside garage. An electric resistance heater might cost several bucks to run each session, but may be worth it. (I wince that my fitness center only costs me 75¢ a day, but the gas for car is over a gallon for a round trip.)
After a year if sag bothers you add a ceiling joist between each pair. BTW are the jousts supported at all from roof rafters?
RMAX Pro Select R-Matte Plus-3, 2 in. x 4 ft. x 8 ft. R-13.1 Foam Insulation Board 637898 - The Home Depot
Rmax R-Matte Plus Polyiso Rigid Foam Insulation Board is perfect to use with wall sheathing applications in new residential and commercial buildings.
www.homedepot.com
this has been frustrating because it’s the only thing holding up my build
