sxk122
I just want a little input before I actually install these lights. I think I know what I'm doing, but I'd like a little input. I am not so concerned about exact code per-say, but I don't want to burn down my house.
My garage (22x23) currently has a single ceiling light fixture that supports 2 60 watt bulbs. I don't have much of a budget, but want to replace the fixture with a couple fluorescent lights. I'm tired of working with a halogen lamp aimed at the ceiling for light.
The garage is laid out like this, pardon my lack of drafting skills.
I am pretty sure I would like to have 5 4' 2 light fixtures. I like these based on cost and look. I generally have 2 cars parked nose-in in the garage. I want most of my light concentrated toward the work bench (orange) and over the front of the cars. I was thinking 3 lights lengthwise at that end of the garage, and then 2 lights at the 'front' of the garage. I want to replace the chains used to hang the lights with 1/4" threaded rod. I intend to run the rod into the attic and bolt them through a 2x4 nailed across the joists. I intend to hard wire the lights using the existing power running to the light fixture. I am relatively certain the existing wire is 12/2 Molex. I want to remove the light fixture and install a junction box. From there, I'll run 14/2 wire to each of the 5 lights, adding a junction box where the light joins into the wire. Wire staple the runs of wire to the joists(that's how all other wires in the garage are secured).
Is there anything I'm missing?
