help with Mitsubishi generator fuel system
trooper1954
Salmon Arm, BC, Canada
Hi all,
Took this older generator apart a while ago, and had to wait 6 weeks for a new carb from China!!! Any how, I'd like some help to re-install the fuel lines....in that 6 weeks I've forgotten where everything should go eek.gif .....and no, I didn't take photos!!!!frown.gif
Here are some photos....I've found a parts manual on line, but it doesn't show this. Any help would be appreciated. Fuel tap.jpgFuel tap.jpgFuel line from tank.jpgcarb. hookups.jpg
The Cobbler
I can't really see enough from your photos, but the line should go from the tank to the valve to the carb . anywhere in there is OK for the filter but I would put it before the valve probably . the higher hose barb on the carb is a vent ( I think) and probably routes somewhere to the bottom of the generator away from heat or sparks
