orangeracer
This is my first post I'm getting ready to start on my 40x64 pole barn located in north central Iowa. The building will have 6" of concrete and be heated using a forced air furnace.
I have access to some crushed asphalt at a decent price so is that alright to use under my slab or should i stick with gravel or sand?
My next question is about the insulation around the perimeter of the slab i've done quit a bit of research and have found where people have went straight down a few feet with the foam board, go straight down and then in under the slab a couple feet, or go down then out away from the building a few feet. Will all of these designs work and is there any advanages or disadvantages to one or the other?
Thanks
Thanks
