Over the last couple of months I've been lurking in the background looking for ideas on how to solve a garage flooring problem. My garage is a typical 24 x 20 2 car garage with a 5'6" x 20 section of that being an 8"elevated bumper that leads into the house. The main portion of the garage floor has become cracked in a few places leading to heaving and unevenness.
I learned about mudjacking on this forum and thought it would be an option to look into. The original idea was to have the floor leveled, cracks repaired, and I would diamond grind the floor and seal with an epoxy product. I got quotes from reliable companies and chose a contractor whose bid would have resulted in a cost of about 1/2 of a total tear out and repour. Since the floor had years of oil, grime, and would have had the cracks repaired with a rubberized product I decided to scrap the epoxy idea and use Racedeck to cover the floor. I also liked the idea of an easier DIY installation.
The contractor mudjacked the floor today and it was a horrible failure. He drilled about 30 holes and pumped a considerable amount of product, but could not get the floor to a point that water would flow out of the garage. His suspicion is that the 5'6" x 20' bumper was added over the original floor which acted like a vice preventing the main floor to elevate. I felt that we came to a reasonable solution and the end result is that he is tearing out the 20 x 20 main section of the floor and pouring new concrete there. The old bumper will stay. Since I am incurring more than I originally budgeted, Racedeck on the entire floor is out. I do still plan to cover the bumper with Racedeck and will now epoxy coat the main floor.
My questions are:
a) how long do I have to let new concrete cure before I can cover in epoxy?
b) I would rather not use a big box type of epoxy; can someone make a suggestion on a quality epoxy/clear-coat that would be suitable for a typical DIYer?
c) Since the epoxy will cover new concrete do I still have to acid wash the surface?
d) How long is a typical epoxy surface coating good for?
e) The contractor will be putting relief joints in the new floor (unlike the old one). Do I have to do anything in these joints to have the epoxy lay correctly, or make the joints invisible?
f) any insight from epoxy veterans that would be helpful is much appreciated.
Thanks in advance for your help! I am always so impressed with how willing people in this forum are to share their knowledge with others.
My questions are:
