mustangmike6996
Long story short: My mother in law has a cottage 4 hours away, we get up north and find that the pellet stove will not start. It hasnt been utilized in 6 weeks but has run flawlessly for the past 5+ years.
I found the instruction manual and followed the failure/cause of failure points to try and diag (with very little tools). All of my diag points to a bad control module which is about $250
It is a Heatilator EcoChoice PN: ECO-ADV-PS35 (im fairly certain).
I cleaned the exhaust pipe and ensured it was free flowing, as well as ensured there were pellets in the feed. I took the side cover off and found that the call light never illuminates to go thru the startup process. It calls out a bad T-stat and some switches. There is no T-stat hooked to this unit, they used T-stat wiring to a switch box with a household light switch. I used a piece of wire and was able to jump the vacuum switch, all 3 cutoff switches and the T-stat wiring but couldnt get it to attempt to ignite or get the call light to come on. The unit does have power and the glass fuse is good (removing and installing the fuse will cause the exhaust fan to run for 20 min as well as the control unit to flash 4 time which is standard).
This unit only runs a few hours a day when people are in the cottage (which is why they had the switch installed in place of a T-stat, I guess. I did suggest using an actual T-stat once the unit is repaired.
Any input for more diagnosis? I dont want to jump to buy her a control unit if I might have missed something small and less expensive.
