Help with Rounded Off Plastic Oil Switch
cliftonbros89
Missouri
I'm working on a John Deere 8400. The hydraulic clean oil level switch went out. It's a major pain to get to. The end of the switch is also plastic and is only made to get a 5/8" crowfoot on it. Yes it has to be a crowfoot with about a 10" extension as there is very little clearance around the switch.
This is the old switch. It came out no problem. As you can see the top end of the switch is pointed. Although it's hard to see in this picture the bottom is actually rounded. This makes it hard to get anything else to fit on it.
I started to install the new switch. However the end of it was made slightly different. I screwed it until it was snug. But, the pointed end (as seen in above photo) needs to be at a 12 o'clock position in order to function properly. The switch became snug with the point at about 3 o'clock. I regrouped and prepared to back the switch off to sit at 12. Suddenly the switch didn't want to budge. I put a little more force to it. It wouldn't budge. After finally trying a few more times the plastic started to round off. That's when things began to become bad.
You'll have to excuse the poor quality of picture. As you can some what see. This thing is not easy to get to. It's up underneath the cab and fuel tank behind multiple hydraulic lines. (You actually have to drain the differential and disconnect a hydraulic line that runs directly in front of the switch just to get to it with a crowfoot.) There isn't even room to get on to it with a stubby wrench. I've tried slipping on a 16mm crowfoot as well and it wanted to slip too. I tried to slip in a rag, towels, rubber and even small metal shims to tighten things up a bit and nothing will work. I managed to shove a strap wrench for oil filters up in and around it. But the end of the switch is almost too small to properly grip around it. Not to mention it's almost at too much of an angle and once the excess strap gets rolled up to tighten on the switch it becomes so bulky there isn't hardly room for it to move in between the hydraulic lines.
At this point I decided to try something different. I grabbed the old switch to see if I could come up with a socket to fit it. A 13/16" socket fit the pointed end the flat sides great. So I grabbed an old socket and cut part of it out to make from for the wire.
I tried it on the old switch and it was a perfect fit. I rolled under the tractor to see if it would possibly slip on to the new switch. Unfortunately, since it isn't made exactly the same it wouldn't fit. It was too big.
After that I decided I'd try a 5/8" socket. I cut it. But it was a 1/2" drive deepwell and didn't have the proper clearance to fit on the switch. So I had to chop it down and ended up cutting the end off an old 3/8" drive socket and put it on the 5/8" socket.
This unfortunately didn't work either. It just wanted to spin on the switch as well.
So, now I'm frustrated and running out of ideas. It's very limited to work space. The irregularly shaped switch end makes me want to curse the person who designed it. This switch has to be backed off just 1/4 of a turn to work properly and I can't budge it. Let's also keep in mind this is a brand new switch that cost a little over $80. I applied some thread sealant, as I'd recommend to the threads of the switch. But it was sealant, not thread lock. It also wasn't dry when it initially started to round the end either. Anyone have any ideas??
**On a side note. If anyone declares any sort of brand bashing on the Snap On crowfoot not fitting properly, neither Craftsman or Gearwrench fit the problem either. This is one of those cases where it's the "fastener" and not the tool.
C
cliftonbros89
Missouri
Correct. Flare but crowfoot won't work. I'm not sure a 12 point flare but would either. I'm afraid it would slip even more.
I haven't tried long bent pliers yet. But there isn't room for regular pliers or vise grips.
matt_i
Good work modifying the sockets, always good to have a few cheap impacts around for cutting, turning, milling to suit.
I think you're going to have to take other "stuff" out of the way, even though that's probably painful as well. This probably went on, early in the assmembly process.
C
cliftonbros89
Missouri
Any chance there is a factory made special tool for that sensor?
Service manual straight from Deere says 5/8" crowfoot
I'm afraid that's what it may come to. Unfortunately that's going to be a lot of time, not to mention more than likely money for new o-rings and what not. Plus most of those hydraulic lines aren't the easiest to get undone either
tjdux
Southern Nebraska
Damn thats too bad. Sorry bud.
gordyy
North Dakota
how about a 5/8 " sparkplug socket with the wires running through the socket then using a wrench on the sparkplug socket? I know not everyone has a sparkplug socket with the six point on the top but I have a lot of old ones around.
C
cliftonbros89
Missouri
I have a few. But I know the plug for the switch won't fit through the 3/8" hole on the socket...unless I'd cut it open more. But even then I'm unsure about the length of the socket. But it could be a possibility.
gordyy
North Dakota
cut the socket off my sparkplug sockets have the 5/8" at least a couple inches inch deep. put a layer of grease on if you do not have any heat sink paste. and use a chop saw
LXCam
I'd try a plumbers basin wrench
Lol, too late on that suggestion
C
cliftonbros89
Missouri
Have you tried carpet tape with small pieces of drywall sand paper to build up on the flats of the wrench?
I can't say I've tried that. But what few things I did try didn't work. It's only a small fraction to fit in on the flat side. I could hardly fit a .005" shim in one one side of the crowfoot.
xjfish
...you're going to have to take other "stuff" out of the way, even though that's probably painful as well. This probably went on, early in the assmembly process.
This. Sorry! You can only do so much farting around before you mess up threads or just plain spend too much time frustrated. Just take it apart more and reassemble carefully. Just my 2c...
Tonyuk
Scotland
Possibly try an anti-slip crowfoot? This would contact the two other flats plus the sides;
Product-S29J4928CF-270Wx270H
turbowoodworker
Apex NC
I look at your modified sockets and all I see is a thread from the next generation of GJ members asking "What is this tool for?". Some old geezer will chime in, "it is for a JD 8400 oil switch, of course!"
:lol_hitti
C
cliftonbros89
Missouri
Pliers are a no go, as are vise grips. Also, tried a 12 point crowfoot. I'm thinking before I disconnect anything else I may have to slide the duals out to get more of a straight on approach to it.
Damn engineers just had to make it plastic.
tthornto
Have you tried warming the engine up first. The iron block will warm up/expand a little faster than the plastic will, theoretically loosening the threads.
tonyprovo723
I like the spark plug socket idea. Instead of a traditional chrome, how about thinwall. The stamped variety that uses a #2 Phillips screwdriver after you lose the steel rod it comes with. These are usually sold for small engines and mowers. I don't know that I have seen or looked for one in 5/8 size.
rayra
Escaped from Los Angeles
was going to suggest cutting a socket, until I scrowled further down your pics.
Time to take a grinding wheel to the inside face of the jaws on the crow's foot, until it fits.
/And when you are done you can paint it John Deere green, because that's all it will be good for.
C
cliftonbros89
Missouri
I'm considering the spark plug socket idea. But that may happen after I slide the duals out.
As far as warming things up goes. I'd have to reattach the line I already have undone. Then pour back in the 20 gallons of oil that I had the drain. Then drain everything back out and undo the hydraulic line again just to hope it may be loose.
stage20
pcola FL
i dont know if there is room. coarse grit sandpaper(36 if you have it) double it over a few times. old serpentine belt and some really good grapping vise grips. makes a good homeade strap wrench with some bite.
FANTM58
Brighton, Co
Can you take an old deep well and make several cuts in it to fit over the sensor. Then hose clamp it to tighten it up. Then just leav it there if you can't get it off.
bulldogr6
Get a cheep crows foot A 1/4 th larger and tack weld a piece of scrap of 1/8 rod on either side of the jaw half way up so it grabs the flats instead of the corners. Kinda like a flank drive or Metwrench.
Sent from my E6782 using Tapatalk
C
cliftonbros89
Missouri
I considered that as well. I may attempt that. Unfortunately, this issue has been put on hold for the time. I've had other things to get done first this week.
bowbridge
Can you get a small C clamp around it? If you can, it might give you more room to grip something on the clamp and turn the switch. Maybe JB Weld a nut to the clamp and turn the clamp? Hard to tell from the pics how much room there is.
pepi
Woodstock, GA
Vice grip? Even a small one might do the trick
X 2 that's what I 'd be trying, if a small Vice grip can get in there. He does not want to go to heavy on the grip and squash or break the switch. Vise grips will dig in and not slip. Then install the new one, only torque enough to keep it from leaking.
He has an old one, that tells me two things..
1 high failure rate of the part
2 when the first one was replaced he over torque this one
BTW:
Forget the ridiculous C clamp idea, they are not designed to work on round surfaces.
All these socket tricks & crow feet have one thing in common, they will fail. The gripping surface of the switch has be compromised, rounded.
Another good suggestion was this basin wrench, if it is what I think it is. It is a wrench that plumbers use to work under a sink. The handle is 8-10 inches long, head can flop to fit the work area. Jaws are like a Vise grip, when it grabs a nut it tightens up with the torque that is applied. Can be seen at the HD.
greg
Abeo
Calgary, Ab
I like that idea.. but instead of rod, I'd use 1/8 flat stock, the width of the bolt. More surface area means the crows foot won't dig into the plastic.
I also like the idea of a strap wrench... probably could make one using serpentine belt and a roll of emery paper and a bit of scrap.
Dragfluid
Pillager, MN
Your modified sockets are just like an O2 sensor socket. (oxygen sensor) They come in a variety of sizes.
I don't understand why a flare nut crows foot won't fit? By looking at the pics it looks like there's room, but of course not being there, it may look different.
But aside from all that, any time I have to remove something that has a bunch of **** in the way, I remove all the **** that's in the way. Less frustration, skinned knuckles, new swear words invented. If something keeps flopping over and won't stay put, mechanics wire it in place.
DGersic
DeKalb, IL
You're modified sockets are just like an O2 sensor socket. (oxygen sensor) They come in a variety of sizes.
Looking at the pics, this thing doesn't seem to have a hex shape. It has parallel wrench flats, but the rest of it is some other shape. You might be able to pound a flare nut wrench on to it, maybe.
C
cliftonbros89
Missouri
^^^this is accurate. It does not have a hex shape a 6 point nor 12 point flare but will work on this.
Also I know that the type of sockets I modified are similar to types of sensor sockets. However, one I wasn't going to pay for those. Two, the 13/16" would've more than likely worked for the old sensor. However, I discovered no such thing will work for the new one.
TractorJeff
Elkhorn, WI
I'm confused?
In the first photo with the Snap-On crowsfoot it appears 6 sided? In another photo it appears rounded with 2 flats?
Which are you dealing with down in there?
BTW
We use the same type of switches in coolant level tanks but ours are 6 sided "Hex".
They are junky switches as we always seem to have issues with them!
All I can think of is to make your own crowsfoot by filing the 2 parallel flats and the 2 angled sides out of a piece of steel, then weld a socket on for your extension. Get a helper to twist it while you get your hand down in there to hold it tight to the switch.
I know it sounds like BS but what other option is there?
Short of tearing into it to get to it.
Duals are heavy especially if an 8400 is the big articulated machine!
BTW: Nice L in your avatar!
Erampu
Waterford NY
Have you tried contacting JD and asking them for suggestions? They might have a trick or two to share.
