Hi folks,
I have a question about putting up steel siding on my barn.
I'm going to be using the standard 3 rib panels, and the question I have relates to the ribs and how they line up with corners on the barn.
After all the steel siding is up, I'm going to need to install corner trims. Those corners come with bend profiles that go over ribs, but what happens if the bend profile of the corner trim lands on top of a rib on one of the panels? How does one prevent having to have custom pieces made and the different corners of the barn all having different corner trims?
Thank you,
Thank you,
