Help with Subfloor Hole Size for 3" PVC Toilet Drain
chris87
I am planning to install my new bathroom subfloor today. I have a 3" PVC riser for the toilet, and I originally cut a 4 1/4" hole. I had seen 4” - 4 1/4” recommended when I was reading other posts. The flange will fit fine, but I realized that I will have a difficult time getting primer and cement applied. I am wondering if I should have used 4 1/2", but I just want to make sure I don't go too large (which I know is bad). I am going to wait until the tile is in place before gluing the flange, so that it sits on top of the finished floor.
Here is a picture with a dauber for reference. This is a larger dauber, so perhaps with one from the smaller cans, I can make it work. I've also seen that they have brushes, so maybe I could use one in this instance. In hindsight, I wish that I had asked my plumber to use a 4x3 closet elbow, so that he could have stubbed up a 4" riser and I could have used an inside flange.
I appreciate any advice!
nmk_61802
Central IL
Do you have the closet flange? If so measure the outside of the hub and add min 1/2-3/4". Your pic looks like you have barely enough room for the hub to fit. I don't work with 3" much, but 3" sch 40 has on OD of 3.5", the hub should be around 4". Jus make sure you are not getting into the flange mounting bolts.
C
chris87
Thanks. You are correct…the flange hub is 4”. Like you noticed, it will be a tight fit with what I have. I was nervous about going too large, and I don’t think I was thinking correctly. Something like 4 3/4” would make it a lot easier for sure.
The Cobbler
you can go quite large without boogering anything up. stay inside the circle where the bolts & screw go, you'll be fine.
I usually cut the hole on an outward angle as a lot of the flanges have an obstruction tight to the coupling portion
