Greatwhitewing
- Joined
- Nov 20, 2011
- Messages
- 531
Thanks so much. Knowing the right name helps. Appreciate it much.WAL-BOARD -RASP [108-WR57] : World of Tools, Masonry, Drywall, and Concrete Tools
World of Tools WAL-BOARD -RASP [108-WR57] - This tool will do a quick and efficient job of smoothing the rough cut edges of drywall. Makes taping and finishing easier. No-load slot prevents clogging. Quick change replaCementblade. Wood handle with hole to hang on belt.Size6 - 4 ozSold by each -...worldoftools.net
Part # : 007-005 - Drywall Rasp - MARSHALLTOWN®
The WAL-BOARD TOOLS by MARSHALLTOWN Drywall Rasp features a zinc-plated, carbon steel cutting grid with a non-clog slot allowing you to smooth and shave rough edges on drywall without the tool getting clogged.marshalltown.com
Wal-Board Tools Drywall Rasp 007-005-HD - The Home Depot
Wal-Board Tools - Drywall Rasp - Smooth rough-cut edges of drywall with this rasp, featuring a high-grade serrated wire grate and an ergonomic, lightweight plastic handle. - THD SKU# 962856www.homedepot.com
