Here a neat technique with cleco fasteners for sheet metal patching
Jogyver62
Oak Forest IL
I had a few old copper buss bars hanging around. So I cut them up for cleco bridges. They work great. Plus you can weld right over them. The welds won’t fuse to copper.
The other tool is a combination cleco / harbor junk sheet metal bridge
WoodsTruck
I bought a Cleco kit a while back. The pliers are so awful that I can't use them. Suggestions on pliers?
ojh
A neat trick with a cleco is you can put a little nick in each panel (equal to the size of the cleco) and the cleco will hold both panels in perfect alignment, even in a curve. The cleco will be right in the seam.
ojh
Can you post a photo?
I apologize for the camera, I'm too stupid to figure one out.
Here's a small piece, I cheated and drilled the holes, sheared the piece and touched the holes up with a rat tail, I couldn't find a washer to back the cleco and used those 8-32 weld nuts.
Then I join the panels with cleco and backing:
With all the cleco's (its very firm and rigid at this point)
Here's the back side:
Washers are even smaller for tighter spaces with compound curves.
Rockable
Oak Ridge, NC
Great tip. I think you could use small leftover pieces of copper tubing for the same. Spilt the tube on a bandsaw and flatten them out. VOILA,
bad_idea
Pasquotank, NC
Don't split the tube - hammer it flat and it will be double walled for rigidity.
I appreciate the tips. I have never used clecos, but have struggled with enough sheet metal.
Monza Harry
Windsor ON
While not as rigid as your excellent idea, plumbing strap could be substituted as well as the copper pipe idea also mentioned above. Harry
