I order a Danmar D-10 ACX 10,000 lbs lift. Installers came to put it up. So these two young men say we are coming to install your lift. Ok, they start etc. One of them looks like he does not want to be there and I kept checking behind him. So I go to get something at Lowes and when I came back the one installing it say this is not a symmetrical lift is an asymmetrical, so I said what did you do to turn, he said he just unbolt the anchor and proceed. So I see something on the floor and it was the anchor that has been cut??? Well everything is done but they try to test the motor and hydraulics with a 110 extension cord, I told them that is not going to work. He said it has work before but not with mine. So I got my electrician to come and wire it etc. I contact the company to see when they can come back and set up and show me how to use the lift and test it. Well, when they get a schedule to my area then will have someone come by and do it, its been a week and nothing yet. So today Saturday 3 December I decided to go to the shop and check the instruction but could not find anything about torqueing the bolts. Be fore the installer left I ask them are you going to torque them down, answer was, not needed the impac took care of that. I told them you not suppose to torque them down with an impact, but they just ignore me. So today I went to check on these anchor bolts, all of them were loose I can just show the wrench to it and move them. So I decided to torque them down to 85 ft lbs. The left side torque fin, then right side is a different story. The anchor at the back of the lift looked funcking, I got closer and I see some type of glue!!! I put my finger to it and the anchors moves up and down?? WTH!! So I pull the anchor and I can see that who ever drilled the hole made the hole tooo big and try to cover it with some kind of cement glue. Then the next one to the corner I can see a lot of threads since it has been shim I looked under there and I can see a washer in the cement hole, WTF!! The others torqued but I have one that the hole is to big and another that looks like is going to come out. First thing in the morning I will contact the company and request the supervisor he was talking all the time when they were working on it. My gosh safety first, they just did not care. I can not image what could of happen if they were able to test this lift. Here are some pictures.
http://vid118.photobucket.com/albums/o108/wickdgt/20161203_142648_zpsnjov2qdb.mp4
http://vid118.photobucket.com/albums/o108/wickdgt/20161203_142433_zpshlrvglob.mp4
The last picture you can see how much thread is sticking out compare to the beside one. By the way, that anchor it comes out easy, and I take it got bigger because it hit rebar so the ***** kept drilling. The question is, will this be able to be repaired?
