The motor gear unit is from Getriebebau NORD GmbH & Co. KG, it's a well-known German company (reliable products), with IEC asynchronous motor (also from NORD), here without fan cowl and probably no fan as sufficiently surface-cooled by the air flow, it's not a Dodge Quantis gear with ABB motor as mentioned in some sales flyers.
There are probably 3 PTC sensors in series to monitor the stator windings, carefully check the rating plate and make sure that protections are set according to the rating plate unless lower settings are required. IIRC protection curves are not the same for NEMA and IEC but I'm not used to NEMA rated motors.
Typically you'll use a VSD. If the RPM's are lower than nominal, sufficient cooling of the motor must be checked. If using a VSD the load can be read out which allows to determine if cooling requirements are met.
In theory, the required power increases with the power of 3 of the speed (RPM) of the fan, therefore even small differences in speed settings have quite an influence on the required shaft output power.
Any basic reliable VSD can be used. Depending on some details PTC's can be connected to the VSD or, in any case, an external PTC relay can, or sometimes must, be used. In some cases insufficient PELV/SELV isolation make external PTC relays mandatory, also ATEX conformity may require it but here it is irrelevant.
It's possibly also a 2-speed motor, if so make sure to connect windings correctly. That said, a VSD is probably still a better solution as the speed can be finely tuned. In such case only the higher speed winding has to be connected; in theory windings could be switched together with VSD parameter set switching but it becomes uselessly complicated and the efficiency gain, if any, isn't worth that implementation.
I'm used to very large low-voltage drive systems beyond 1.5 MW per motor but only IEC, not NEMA.
