here's mine
ArthurPE
almost embarressed after the 'bunker' garage and some of the others... ;)
24 x24
it was pretty crappy when I started, my budget was 4k...
so far:
-scrubbed clean, painted
-new floor
my brother owns a company that does industrial/commercial flooring, he recommended it...iirc it's a German company
ARDEX Engineered Cements > Company Overview
This high quality Portland cement-based product mixes with just water and readily bonds to all concrete surfaces, providing a durable, new wear surface suitable for foot, rubber-tire, and automobile traffic. ARDEX recommends the use of ARDEX CG Concrete Guard to seal and protect ARDEX CD, both interior and exterior.
Benefits:
Provides "new concrete" finish to worn concrete surfaces
Bonds as thin as 1/16" (1.6 mm)
Easy prep - no scraping, primers, or pre wetting
Portland cement-based - High strength - 4,000 psi
Mix with water only, no additives needed
Fast and easy, apply with a trowel or squeegee
Dries fast, walk on in 2 hours, drive on in 6 hours
it's an epoxy/cement mixture, trowelled on, 6 hours to dry for use...
surface prep, wire brushed, adhesive coat, then apply
looks like fresh concrete when done, I sealed it with 3 coats of water based sealer...took less than 8 hours and $300...
easy to patch if required...very hard, difficult to scratch...I've dropped tools and not damaged it...if you apply it with a 'broom' finish, very slip resistant
-new openers, custom brackets, knee bent
-storage bins, door on shelves, work bench
-blinds, prints, wall clock/thermometer/humidity
-wall mounted TV, 26" LCD w/DVD
-aluminum floor jack, wall mntd shop vac, shop cart, reel light, fire extinguisher
-stools/chair/table (not in pics) Ikea stuff, black & SS
-new door to house
-grey cove molding
-new GFI's
-lighting, 8 x 65W recessed can
left to do: 15k BTU mini split unit heat pump
Jack Olsen
Los Angeles
Looks nice!
Do you have any pictures of the floor material being installed? Or close-ups of what the surface looks like?
On the Mini side, is that a glass door leading to an adjacent room? Cool to have that, if it is. My garage and my home office are both part of one structure that's separate from the house, and I've always wished there was a way to put a window between the two.
e-tek
Saskatoon, SK
C-mon - I LOVE the glass door! Makes your ride a focal point and art display! Too bad my door isn't where you could see into the garage....hmmmm....
slim53
Bloomington, MN
Well done sir! :thumbup: Would love to see some progress pics. How much did (or in your case, how much would it cost since it was your brother) to do an overlay on the cement? I need it bad at my place.
Slim
A
ArthurPE
Looks nice!
sorry, no progress pics
it's just mixed with water and trowelled on...application <1 hr...
prep and bonding coat 1 hr
took less than 3 hours
the surface looks like fresh brushed concrete...a bit whiter...
very hard, like epoxy, with a cement texture...
the door leads to the kitchen area...my wife can keep an eye on me to make sure I don't get into any trouble lol
cost: goes without saying, varies by region
material: $100 or so
labor, 2 guys 3 hrs max
I had the area emptied for them...started at 2 PM, out of there by 5...
I let it cure overnight to be sure...6 hours per the instructions...1 hr to walk on...
thnx guys...next ebay mr slim heat pump :D
