Here's one for Ya!!!! - Propane
sarge97
I'm being told by some propane experts (?) that if I paint my tank with "Cow Spots" (grand kids and I want to paint the ole ugly thing) that nobody will fill it up because the black patterns will cause the tank to get to hot and become dangerous??????? I'm pushing the BS button,,,, anybody heard of anything like this,,,
Thanks
A_Pmech
IL
Black paint collects substantially more IR radiation than white or silver paint resulting in higher surface temperatures. Higher surface temperatures result in higher LPG temperatures, which results in a higher vapor pressure. This is why they paint propane tanks a light color.
It's a common enough fad out here in farm country that I suspect the gas suppliers are indifferent to it. Call yours and ask.
Steevo
43.49600, -112.04300
Check these out:
http://www.interiorinstallations.com/catagory_pages/water_propane_tanks.html
and here:
and here:
dave67fd
Southern NH
I have seen white tanks as well as medium to dark green tanks as well as propane dist. logo's in dark blue here. I don't disagree with the dark spot "theory" but think it's more related to the distributors/gas companies just don't want you defacing their tanks.
slip knot
Texas gulf coast
I think they paint the tanks a light color to make corrosion issues easier to spot. I've got 3 tanks that are silver and one that is dark green. All are owned by me and all are serviced by the same company. I never had any questions about tank color.
All 4 are located in south tx sunshine and get hot in the summer with no pressure issues to date.
2drx4
Northern BC, Canada
As per all of the literature I've ever read, painting them a light colour was to help prevent heat from solar radiation causing an overpressure situation. That said, real world practice found this to not be relevant, and I nobody really makes an issue of it anymore. If you're renting or leasing a tank, it might be an issue simply because the tank isn't yours.
6768rogues
Western NY
Tanks are always provided in light colors because of heat gain with dark colors. A few black spots won't make much difference. Ask your supplier if they will fill it with spots painted on.
Full Throttle
There is, but you don't want it to pop. All it takes is an ignition source, and you've got a BIG bang.
a full tank sitting in the sun in the mid of summer, will pop alot.
regardless of color
