Here's The Dumbest Question Placed on GJ
cpakalolo
I have to give you the approved way of working on any electrical circuit. You should do the "Off-ON-Off" method we all are told to use. Go to the light and compare the voltage between the button on the bottom of the socket and the aluminum ring the bulb gets screwed into. You should see power. Now turn it off and check the same way to see that it is off. If you already have the power off, then it is off on off. You proved your meter was working in the process. Your wire strippers rammed in there often do the job. Usually, the cement is still in the socket, so you might have to test against the wire in the middle of the cement that connects with the button on the bulb. Some LED bulbs and CFL's have a nail or tack looking button which will not retain the wire when the bulb twists off. On these, it might be hard to find the hot wire and you might have to do it hot anyway. Chuck
nadogail
Coronado, CA
Trying to determine the dumbest question puts you in a league with a lot of competition.
Sometimes a I read the questions and am reminded of how dumb I used to be.
Chipm
Georgia
I’d start with the ol taste test, just so you know what type base you’re working with.
When my daughter was little, she crawled by a 12v charger for one of those robot vacuums on the floor and somehow got the cord in her mouth. She was bawling, and I told my wife it was only 12v and probably didn't hurt that bad. So my wife said, "fine - you try it." And it turns out 12v hurts pretty bad if you lick it.
MR2FC
Did the 9v battery as a kid (didn't we all?)
So it seemed a natural progression to try it with the 7.2v batteries we used for RC car racing, and that was a properly painful experience!
As they say, it's not the volts that get you...
