hex crimpers for battery lugs / terminals - recommendations?
R-mm
Hi all
I have a hammer crimper which works just fine. I'm going to be wiring up a car or two and sometimes find myself making parts to sell / give forum members. So I'd like something better than the hammer crimper. Next up project is are some short 2AWG jumpers with these terminals; https://www.waytekwire.com/product/crimpable-battery-lug-36303-negative-post
TEMCo TH0006 looks like a nice hydraulic kit with all the dies I need. At a price the whole family can agree on, shipped free.
This one from Powerwerx is about the same price. Shipping is a bit harsh at $32. https://powerwerx.com/hyd-2-hydraulic-crimping-tool
38 Dodge Coupe
Delaware Ohio
After many years of making due, I bought the Sanuke Hydraulic Crimping tool with cable cutter last month off of Amazon. It was a returned item so they discounted it, but for all practical purposes it had never been used as far as I could tell. I needed it to make terminal ends for an auxillary battery that I added to my GMC. I surprised myself as my first crimp was perfect!
bluedog225
Texas
The Temco are nice. Free replacement (for any reason). Need to check is still the case.
Instructions are not great. Something like “continue until you feel resistance.”
Better to eyeball the gap between the dies and stop before you bottom out. I broke one with too much pressure.
WisJim
Menomonie, WI
We had a cheap one that did up to 4/00 cable that I used for battery and inverter cables for solar and wind electric systems and my son still has it, I think, and uses it for electric vehicle cables. I'm sure it was under $100 and worked fine for us.
gte718p
Th dies are market wrong, but honestly the HF crumpets are pretty good. I have mad dozens of EVs using them.
mm08822
Lugs have to be sized for the specifics of the conductor. The strand count within the conductor is a major factor in lug size selection.
Dies may be impacted by this as well.
Reputable Manufacturers have the these details in their products' cut sheets.
mm08822
Before heat shrinking the crimped lugs, make sure there is no lead squeeze-out occurring where the die sections meet.
Otherwise the squeeze -out can be razor sharp and cut the shrink wrap.
BreeStephany
Oregon
I have that TEMco its a nice set.
I also have the TEMCO set and it does great for what it does. It's essentially the same frame and general design as the HF version, but actually holds oil and doesn't leak right out of the box AND there are rare earth magnets in the die holders that keep the dies in place which was a very nice surprise when I bought it.
It does everything up to 2/0, for 3/0 - 750 KCM, I have a Greenlee compound crimper, but haven't been doing a lot of crimps over 4/0 these days so I haven't really felt the need to jump the fence for a nice Milwaukee ForceLogic set as of yet.
cgrutt
Not sure but don't believe HF includes the "+" size dies either.
