Hex tool for tight area
skeaner
I'm installing bathroom fixtures, (vanity mirrors, towel rack etc.) The small size hex fastener, small little Allen wrench they give you and a very tight space make installing these fixtures maddening. There has to be a tool that builders use to make installing these types of fixtures much less frustrating....HELP
MR2FC
Look at quality RC brands, I have the Yeah Racing which are OK, but Hudy, MIP or EDS or Arrowmax seem to be the best
Beerhippie
Far NE Oregon
I just use an angle grinder and cut-off wheel to make the keys the manufacturer includes with the fixture into a low-clearance wrench. Then I throw it away and refuse to ever work on that fixture again.
We had no-touch faucets installed in our bathrooms that required annual battery changes with a stupid Allen nut retainer right up against the wall. I think I "accidentally" broke them all and replaced them with ones that had the batteries mounted below the sink.
garfunkle24
Saskatoon, Canada
I have no idea why anyone would buy general use tools from a niche market supplier. I get buying speciality stuff but why on earth would a person buy hex keys, wrenches, screwdrivers etc from such a place?
I see it with RC guys, bicycle guys with their Park stuff etc.
How would the OP benefit from a fancy tool from an RC supplier? Do they need the ultra light weight? I doubt it.
Pretty sure the OP just needs some ball end or low profile hex keys.
MarcSeattle
Seattle
My favorite would be the Wera hex keys with what they call the "holding function" (spring loaded ball) so it's less likely to drop a screw.
Another option would be the L-keys that have a flex joint at the corner, made by Bondus.
garfunkle24
Saskatoon, Canada
Just a note top add that those are made in Taiwan (as opposed to most Bondhus) and more "made for" Bondhus than "made by". I bought them under a different brand many years ago.
They work well for some spots and the flat section at the hinge is easy to put a wrench on. They're handy to use this way when you need a long non-ball end key. The short end is a bit on the long side for my liking though and you can't shorten it much.
KnurledNut
n/a
I like to use long bits standalone to spin them in and finish snugging with a small driver handle.
MR2FC
An RC driver has a small diameter handle allowing you to get close to a wall or door without worrying about scratching anything with the bare end of an Allen key, and obviously saves time if you have a lot to do.
RoninB4
Under My House
You want a ball end hex wrench. Allows you to move the other end away from the wall enough to rotate it.
A ball driver is ok for running the screw/set-screw in but NOT for tightening. The reduced cross section of the neck can/will snap off fairly easy. This has been covered numerous times.
mike93lx
Richmond, VA
Its completely adequate for a towel bar in my experience. But, as it turns out, only one end is ball, so even if it is weak, you still don't need a second tool. Just turn it around.
The ridiculousness of suggesting a bit ratchet is peak garage journal
