Trey T
^Yup, exactly what I was gonna say but that would've been a far leap to my main point.
on occasion, property managers and their "preferred subcontractors" work together to hustle money out of property owners..
preferred guy gets paid to repair the defective component, property manager gets to send you a bill for the repair cost "plus their markup"..
I'm just sayin'
This isn't directed at anybody, it is just a statement of my thinking on this.
Going with the lowest bid (or taking the cheapest route) doesn't necessarily mean you saved money, in the long term. It may very well mean you will be spending more money in the future than if you had gone with a reputable company and got a high quality product and competent service in the first place.
Not could be from the 1970s, it IS from 1974. It runs through the concrete slab.It would be plain and simple stupid to not replace the line set that could be from 1970s.
Line sets should be changed every time you chane the unit.
Sean doesn't do installs, he is exclusively service. He has helped me out before on my mini-splits by doing the nitrogen pressure test, charge, and testing after everything was installed. He charged me his regular service call.that is what my thoughts are, Sean helped you out, now it is your turn to help him out. Let him do your install.
So here is the final decision:
I picked up a lug repair kit and installed it myself, and the damned thing fired right up. Talk about DIY. $15. BUT, the system is not blowing cold and I have pretty much made peace with replacing it.
I've got a pissed off tenant, and incompetent property manger, and no time to deal with it anymore.
Sean knew a "guy" that was just starting out who he says was "not stupid." He's young, but he is licensed so I figureded I would give him a call.
He is the only guy who actually went into the attic of the three. He saw it was a straight shot to the outside soffit from the top of the inside air handler. Cost is just about the same as Sean's company, but his quote included everything from inside to outside new. He is re-using my condensate pump, my thermostat, electrical, and my existing ducting.
The equipment is Concord instead of Goodman.
Here are the specs:
Concord 4HP14L30P-10A
Concord BCE3M30C00NA4X-2
ECP25-S-P Heat Strips
3/4 inch copper 50 feet
3/8 inch copper 50 feet
Preflex 06 (I don't know what this is.)
36x36 concrete pad
New control wire
New metal line-set cover for outside x 18 feet
This doesn't include a new condensate drain run, but he said that if I run new PVC and I am not in his way, he will cover it with the line-set cover for me as long as I don't slow him down. Currently the condensate pump dumps the water into the washing machine drain.
He told me that new copper was only $200.
He also said I would probably need a new outside power disconnect, (Currently it looks like an outside light switch) a new whip, and it wouldn't hurt to run new power wire since the current wire is not view-able.
I could have all that run since the breaker box was next to the inside air handler. He also said that wasn't included in the quote and he wasn't going to do it but I could call an electrician.
The breaker box has two breakers for AC, one 50 amp and one 20 amp. I am not sure which goes to the air handler/compressor. I have to figure that out. I hope 50 amp is enough to run this system. Maybe I'll ne) d a new 25 amp breaker, I'm not sure yet. Its going to cost me $75 for the electrician to come out and give me his opinion, but that will help me sleep better.
The current system is a 2 ton straight cool AC with a heater box that does all the heating. The new system is a 2.5 ton Heat Pump. The condo is 925 square feet, but there is a whole wall of windows that really heats up the place in the summer if they aren't covered.
Paid half up front, will pay remainder when its done.
Work starts Sunday at 7 am. Cross your fingers!
Maybe, but I hope not. There is an entire wall of windows facing the sun and it does get really hot in August.2.5 ton for 925sq'? Won't it get cold and not run long enough to remove Florida jungle humidity ?
BrianWell, the system is in. Had a leak during the nitrogen pressure test but he fixed that pretty quick. 55 feet of copper line-set with a street elbow on the inside unit. Everything else is very slow gradual bends in the line-set. Only brazed joints are at the unit and the air handler.
Cold line is wrapped in insulation. Whole mess is tied together with wraps of electrical tape along the line. The line is supported in several places with loose fitting screw down zip ties. He seemed especially concerned with the 90 degree turns down to make sure there was no weight pulling on the bends. He said too much weight could make the line-set crimp over time. So it pops up in the attic with about a 3-4 foot radius on the 90 degree attic bends.
Its blowing cold. Says I need a water trap on the pan drain line. It comes out of the pan and goes straight down, then a 90 and another 90 and into the pump. The pump is only 2 feet away. Can the system **** the water back up into the air handler?It can impede draining when the indoor fan is running by either forcing air down or sucking air up the drain line depending on where the coil is relative to the fan. This high velocity air keeps water in the pan and can spill over into the unit.
That's about it. I am going to wire a condensate drain cutout to the pump just in case. I'm not exactly sure how to do that yet but I think you just wire up the leads into the proper wire when I figure that out.Just have it cut the R wire to the thermostat. If you see the display is blank on the thermostat you know it is the pump level and makes for a quick first check.
Also, that sump pump water is nasty, I need to do something about that. It keeps a few inches in the sump until it kicks on, so I am going to look into getting some of those purifier tablets.This should be part of your annual maintenance to clean out. Put the tablets in the pan not in the condensate pump. I have had them get sucked into the pump and kill the pump.
Quick correction:
I thought it was one straight run of copper, but its got a **** joint about 6 feet off the ground right before it gets to the compressor. Its covered in insulation but its a clean enough solder job. Plus it should be easy enough to test for refrigerant leaks if I have any in a few years because its right by the outside unit.
Apparently you can't get longer than a 50 foot line-set around here. So I got two coils of 45 feet of new copper that I am going to toss in the attic. (3/4 and 3/8 line set)
I am searching online for something longer. Might as well start planning on replacing the AC at the other condo.
It's common to have **** joints near the machines. However, if anybody using couplers for residential install is quite behind on installation methods, very in efficient.Quick correction:
Your contractor supply house can order 50ft+ of lineset but you have to wait. This is one indication to determine if you got a good tech or not, if he's organized and prepared a head of schedule.
You're a masochist if you like running 100' Line Sets in anything bigger than 5/8 trying to make a bend or 2 with a bender in the middle of the lineset is just begging for a kink. We would not run anything more than a 50ft then swage and braze the line sets together while nitrogen purging to prevent scale.
Brian
We demand installed pictures so we can critique.
Brian
