HF 20# blast pot
Tynee
In the Heart of the Bluegrass
Pressingonward
SW WA
I just bought one a couple weeks ago, also a noob to sandblasting. I haven't tried walnut shell; I've been using aluminum oxide. With those caveats, here is what I've learned so far:
1.) The instructions it came with are wrong. They tell you to open the sand valve (on the bottom of the pot) all the way and regulate mix with the valve on the air bypass hose (I forget what they call it). Instead you need to regulate mix with the sand valve on the bottom, and open the bypass valve all the way or nearly all the way. See this youtube video:
2.) The nozzles that come with it are too small and wear out too quickly. I plan to get a new 'gun' for it that will accept heavier duty nozzles
3.) You will need a moisture trap. I added a pressure regulator with built-in moisture trap followed by a second trap. I had to drain the first one every 5 minutes or so as it would fill up.
4.) I plumbed two compressors to it for a combined 10 cfm. This was just enough to run it almost continuously at 40 psi, which is the minimum usable pressure. I just bought a 240v compressor to add to the mix for 22 total cfm running all three in parallel. I will look at the charts online when I buy the new gun and nozzles to see what size nozzle this will support at ~90 psi. I'm thinking probably an 1/8th inch nozzle based on one chart I saw, but I need to dig further. There is probably a minimum nozzle size you'll need to run walnut shell.
Hope this helps!
73RR
Blank Email
Central Ory-Gun
I have had one for about 20 years or so and have used it many times with Green Diamond in several grits. As mentioned, the ceramic nozzle wears quickly but maybe walnut shells would not be so bad.
It requires a lot of air to work.
gungatim
west mich
based on some of the comments, I assume they have changed these somewhat.
when I bought mine, it came with a moisture trap, and a bag of various sized blast tips that were decent quality (and I've only worn one out so far).
the one thing I did was to add a different air release valve to the top for draining the air out of it (the brass one it came with *****, I used a small industrial flow valve which works much better without clogging.)
I haven't tried walnut shell, only black beauty and regular sand. I did see HF sells a conversion kit for soda blasting so maybe they have one for walnut shell as well. IIRC, there was a thread a while back on some mods to make these pot blasters more efficient, but it's probably buried a few years back...
ovrrdrive
Central Florida
Be sure to check out the blast cabinet thread pinned up top in this forum... Lot's of good info there. If you're serious about blasting at least consider the gun upgrade. Makes a huge difference in performance.
ScottsGT
Lake Wateree, SC
I used one about 20 years ago as well. First off, you have to use a fine grit sand. Cannot use "Play sand" from Lowes or Home Depot. It's just too course.
I have no idea if walnut will work. It's pretty coarse.
Must use great water traps. Mine came with one installed, but I installed another.
The valves. I found out I had to tinker with opening the valve slowly or too much too fast would just clog up the line.
May have been a few other tricks I used too, but like I said, it was 20 years ago. It was very temperamental to get working right.
