Hf 20 ton press
midas
I picked me up a 20 ton press from harbor freight finally. First use is for a transmission rebuild. I quickly found out that I need the base opening wider...it current measures four inches and I need about six to get gears inbetween. I have not been so lucky searching for ideas on widening this sucker. This is my first press and I was tempted to just lower the base and put cinder blocks on top to get my needed width...but not sure how safe that would be. I was thinking of cutting the straps and bolting in some extensions, but once again I am not sure if that will kill the structure Any ideas?
jrobb316
WI
Cinder block isn't a good idea. Maybe steel blocks. That's why I hate that press and made sure I bought one with a 7-8" table(not HF).
MJD1
Get some wide flange beam cut offs. Set them so the web's are verticle. If needed you could tie them together, but probably not needed.
M
midas
Went to a steel shop...going to get some c channel from there tomorrow. I don't know why I wasnt thinking of doing that. Thanks!
owenst7
Anchorage/Reno
Not sure I understand your issue. I've done a lot of 1-ton axle re-gears along with wheel bearings and a couple turbo hydramatics. Haven't had any issues with the table yet. I was always taught not to press directly on the table so as not to gouge it. Using arbor plates allows you to easily file or grind any gouges so that you can maintain a flat working surface.
I use my arbor plates to hold stuff off the table.
The SWAG arbor plates are a great size for that press and are much larger than the stock ones.
M
midas
This is what I am working with...
DenisG
Milwaukee
I use spare C-channel for similar jobs. They have holes so I can take it apart and adjust the spacing between supports using 5/8"-11 bolts and some pipe (spacers). I also keep some longer 3/4" solid steel rod on hand for the vertical supports on the wider temporary table.
M
midas
Well that was stupid easy. $40 for the steel. At least I have it for future projects.
