SeisMec
Not sure this is the BEST assembly procedure, but it beats the h#&% out of the instructions that come with the cart.
If you can, unbox the unit before leaving the store lot and check that everything is there. Mine was missing:
Corrections to Parts List:
Items 1 and 6 (leg posts) are the exact same part - laying one to the right and the other to the left does not magically change them to right-handed and left-handed parts. BUT THEY DO HAVE TOP AND A BOTTOM. The carriage bolt hole at the top of the post is about 1-3/8" down from the top. The carriage bolt hole at the bottom of the post is about 3/4" up from the bottom.
Tools required:
2 - short pieces of 2 by
(Under the back of drawer section while assembling legs.)
1 - 13mm combination wrench
(Nuts on leg carriage bolts & gas struts.)
***1/2" was a better fit on mine***
1 - 12mm combination wrench
(Hex portion of studs on gas struts.)
1 - #2 Philips or a medium slotted screwdriver.
(Morphodite heads of caster bolts)
How to:
- Both handle attachment bolts.
- One small drawer liner.
- One washer for the casters.
Tools required:
How to:
- All nuts/bolts are attached finger tight until told otherwise.
- After taking everything out of the box and inventorying it, open the top of the drawer section and remove any loose parts from the inside top and drawers.
- Lay the drawer section on its back (drawer faces up) on top of 2 bys.
- Open the drawer section lid.
- Attach all 4 legs to the drawer section. Remember they have a top side.
- Attach each Cross support to a pair of legs - match large-small holes with holes in top - the small tabs face the drawer section.
- Remove the 2 bys.
- Attach the bottom section to the legs.
- Attach the casters to the bottom section.
- Fully tighten the nuts/bolts attaching the casters.
- Close and lock the lid.
- Stand the cart backup on it's casters.
- Open the lid.
- Fully tighten all the leg post carriage bolts.
- Attach the gas struts.
- Attach the handle.
